Strange "bip" interference over WTWW Lebanon/TN Christian broadcaster
Short recording of a strange “bip” interference over WTWW Lebanon/TN Christian broadcaster at 5.920Mhz on the 49Meters band… Couldn’t identify the origin of the interference signal but it seemed to come from the original signal itself being transmitted as no other secondary signals where present on the same frequency at the time of the recording…
That’s what is known as a SLB “Single Letter Beacon”. It’s sending the numeral 5 repeatedly. Whoever knows who is doing it, and why, is not talking.
It is sending on 5921 kHz should you want to go looking on other forums.
If you tune around you’ll find many SLB’s around the lower bands, not all in broadcast segments either.
Some are far away, as they are affected by global propagation, others are very strong all the time, so must be relatively local.
It is very strong (S9++) here in central UK (October 16th @ 08:00 utc) so could originate from the UK, but that’s not guaranteed, the strength of it is varying. Try the KiWiSDR network, I’m told there are ways to use that network to locate the approximate origin of a signal.
There are other forums dedicated to such wierd things, people “collect” (log) them!
Dave in the UK.
The “Bip” has stopped at 08:25z (Oct 16th) There has been a couple of single long beeps, but at present (08:27) it’s silent.
Maybe they are reading this list? :laughing:
Spoke too soon, it’s back as of 08:29
Off again at 08:54z
Single long beep at 08:59z
Silent since then at 09:10. Recorder running, out of curiosity…
Dave.
