Depending on the propagation issues its depending also on location and terrain also depends on the right antenna setup as I tried to pull in other stations
Can you add more context?
In other words if the solar flares are higher and active it could be better propagation how ever, if in some cases depends on location and terrain like being up higher ground could improve reception,
