I decided to create a new topic dedicated to sharing apps, software and hardware related with the radio hobby… Feel free to leave your info and download links…!
This is a very useful free map software by the same man that created the SDR Console software.
Simon World Map
It shows the world map with longitude clocks, locator grids, greyline, aurora, Sun and Moon position, Satelites position, short/long path info and indicator, and more…
Lust give it a try it is no doubt a great radio activity map.
You can download it here: https://www.sdr-radio.com/world-map
Good idea for a topic! I use a lot of different software packages and am always interested in trying out more.
For anyone interested in digital modes I recommend checking out MultiPSK. It can decode a large number of modes used on Shortwave, VHF and UHF, not just Ham Radio use either. The interface is a bit complex/messy and there’s a steep learning curve on how to use, but help is also available. You can try the free version before paying for the “pro” version that gives you more modes.
Download link is here: http://f6cte.free.fr/index_anglais.htm
Is this a useful gadget or just another useless snakeoil project…?
https://hackaday.com/2026/05/04/a-shortwave-sensor-to-monitor-the-ionosphere/
I get the concept of that but can’t see it being all that useful. I do consult the solar activity info to look for band openings but you can simply use your radio and check to see if you can receive transmissions or not.
I’m not knocking the science of the product, I would rather spend the money on items I can use more effectively,
A great platform for Radio Ham’s and SWL listeners with loads of different options: DX Spot, Logging, Space Weather, Call Signs database search and even CAT and SDR (RTL-SDR only) remote control…
Just check it out here: https://hamdash.com
Unfortunately one of the cheapest and best SDR receivers on the market capable of HF receiving is now finished…
RTL-SDR V4 will not be made any more…
News here: https://www.rtl-sdr.com/rtl-sdr-blog-v4-end-of-line/
A great site for all sort of gadgets and DIY projects for radio “nerds”…
Antennas, amplifiers, receivers and all sort of stuff radio related.
Check it here: https://vu3dxr.in
I tried at least 3 times to order one of these - 2 of them were lost in the mail and the other went out of stock around the time I ordered. I’ve had good luck with nooelec SDR’s for cheap setup items and they’re much easier to order (for my location anyway).
I got myself a SDR Play MSI RSP1 Clone… It’s a bit better than the RTL-SDR V4 but for the other side the RTL-SDR has more compatibility with software except the SDR Play of course…
I’m quite pleased with my clone, it’s 12 Bits /10Khz bandwith instead of the 8Bit/4Khz of the RTL-SDR… And it is still available. On Aliexpress there are loads of fake V4 RTL-SDR’s that in reality are just V2 or V3 with a V4 case so be careful with that…
Space Weather Ops Online app…
A great page to be aware of all the Space Weather phenomena and previsions…!
Here: G7IZU Space Weather Operations Centre – Live Solar & Geomagnetic Monitor
Anyone interested in building a cheap and efficient directional mono-band antenna here is all the construction info for a Moxon antenna:
I found this Artemis Radio Signal Recognition software to be helpful in making sense of signals while monitoring radiowaves using SDR.
To anyone that wants to register their signals listenings, here is a great platform for that…
REU/Signals platform.
Check it out here: https://rxx.classaxe.com/en/reu/signals
I’ve been thinking about building a couple of these for different bands. It’s a very cool design.
Hi there,
Not necessarily hardware specific to shortwave listening, but I will mention it anyway. I use an Olympus microcassette recorder to record programming. It has an audio passthrough feature so I can listen while it is recording and pause edit on the fly. I am able to connect it directly to the headphone jack on my Realistic DX-350 with no issues, but if I want to record from my Sangean ATS-505, I need to use an audio mixer in order to not overload the input to the tape recorder. Someone on reddit mentioned an LZSIG model that’s inexpensive and available on Amazon. It works fine but is inconvenient to set up, so I find myself sticking with the DX-350. Shortwave isn’t particularly high fidelity and I’m quite fond of the microcassette format, so for me it’s a perfect match!
